The aim was to create a smart overview to use in the future. I don’t care if Agenda find anything at the moment.
If Agenda give the search result ”not find” the “create overview” button disappear. A workaround is to temporarily add items to find and save it in “create overview”. After that delete the “dummy” item that shouldn’t be there.
The “create overview” button should be there regardless if Agenda find anything or not.
