Hi all!
I can’t seem to make a URL for create-note work without a project= attribute. I think it is supposed to be that the currently selected project is used if not defined, but that doesn’t seem to be the case.
Am I doing things wrong, or is this a defect, or any thoughts?
ScottyJ
We have heard the same thing from someone else. We are going to investigate. Sorry for the trouble.
I managed to find the bug. It will be fixed in our next release. Thanks for reporting it!
No trouble at all, wow thanks for the quick fix!
Update: we believe this should be fixed as part of Agenda 15, let us know if that’s not the case.
