Is it possible?
Thanks for the clear video. At the moment you can only create new projects inside the sharing extension, not a new category of subcategory. We think that creating a new category and/or subcategory is something you would do so infrequently that it is not worth adding that functionality to the sharing extension. In addition it would probably not be very friendly to do it there without having context of the entire sidebar like you have in the main app. Hope that makes sense?
Ok thanks for the reply.
I’ll work on a new process
