Crash when dragging note to another project
What I did: drag a note from project A to project B
What happened: Agenda was erased when I was dragging a note from project to another project
What I expected: Note is moved to the target project
Agenda version 13.1 (upgraded yesterday) / MacOS 11.4 / MacBook Air M1 chip, you can refer the screen recording in below links. Thank you. (https://mork.ro/Nnf5F)
I’ve tried to select 2 notes and move it by dragging, it works. But if not work for dragging 1 note among projects. Thank you.
We are indeed aware of an issue when dragging a note from one project to another, we’ll fix it ASAP.
We’ve just pushed the 13.1.1 update into beta, could you give it a try and see if the crashes are indeed gone? You can download it from http://downloads.agenda.com/Agenda_13.1.1.zip
It’s been fixed in this version, many thanks!
