I’d like to use “Copy to markdown” to copy snippets of notes to other apps but instead of just copying the selection, it copies the whole note.
Is that a known problem?
This is correct, at the moment it copies the entire note. We’ll see if this can be adjusted in the case you have a selection.
On the Mac, if you select some text, right click, and choose Copy As > Markdown, it will only take the selected lines.
Ah, fantastic. While keyboard shortcut would be useful this will keep me afloat in the meantime
