What I did: tapped context menu for project or category. Select “copy as agenda link”. Paste in another app. Nothing is pasted. No text sent to clipboard.
What I expected: agenda link pasted to the other app.
Things that might be helpful to know (Agenda version, OS and model, etc): 9.0 iOS 13.2.2
I don’t think this will do what you think. Agenda is not a web app. You can’t share a copy of a project with a group online, like you can with web apps like Notion.
What you can do is share individual notes. When you do that, a copy is put in the cloud to share with others. So it is a different model.
If you create an Agenda Link, it will only work on your own devices, because only your devices have the data.
