Copy and paste folded (collapsed) note sections
Select several collapsed headings, then copy and paste them into a new note.
Only the headings are inserted.
The collapsed text is ignored, not copied and not pasted.
The headings and the collapsed content are copied and pasted one-to-one.
The original formatting (including the folding) should be retained after insertion.
Agenda V20.0.1 (337), all OS platforms
OK, so it is just taking what you see on screen when you copy, not the folded paragraphs.
Yes, sounds like we overlooked that. Will look into it. Thanks!
:technologist:t2:In Progress.pdf|attachment (42.3 KB)
The attachment is from an example of this bug done during a print preview. The bullets showing are in the collapsed section. In the note it’s folded as expected. Also you can’t unfold the copy.
Definitely something we overlooked. Will look into it.
