That should allow us to see what the app is doing while it is working so hard.
Also, does the console.app (which you also find inside your Applications folder under Utilities) output any Agenda related error messages?
Best wishes,
Alex
Hi There,
I just realised that Agenda was using over 2GB of Memory on my MacBook Pro which. Usually, Agenda keeps on running without any restarts during a week or so. Unfortunately, I stopped it already which prevented me from taking any dumps. After a restart and a few minutes only by now, It’s using around 100mb - which is still more than the ‘usual’ app…
nest time when I realise it using too much memory, I’ll take a sample and send it to you…
I’m using the latest beta 9.1.1 (101)
Cheers,
Christian
p.s.: edited 6h after restart of the app (and the mac 3h sleeping) - the usage went up to 555mb…
We are indeed aware of a memory growth issue reported by some users but haven’t been able to really locate the source yet, we have some fixes that we might ask you to test if that’s ok.
If you could download it, drag it to your Applications folder, and then try it out, it would be great. We are not so concerned with short term rises in memory, which can be completely normal, but if the memory doesn’t drop off after say 15 minutes in the background, there may be an issue.
