Hello it would be amazing to have check lists move to the bottom as they are completed. I find myself switching between the reminders app and agenda app and wish agenda would imply a simple check list as so.
Still love the app, hate switching between both.
Agenda has a bit of a different approach to reminders. It deliberately keeps around what you have finished, ie, the whole list.
That said, you have some tools to work with, especially on Mac. See the Edit > Checklist menu. It has a bunch of operations, like moving checked items to the bottom. If the cursor is in the line you are checking off, you can hit that to move the item. Or select part or all of the list, and do it all in one hit.
Hope that helps!
