I have a checklist with a number of items, some checked, some unchecked. I clicked on the circle at the beginning of one of the lines to check the box.
Example 1:
[ ] item 1
[ ] item 2
I click the circle at the start of the line for item 2
Example 2:
[ ] item 1
[ ] indented item 2
I click the circle on ‘indented item 2’
Sometimes, when I click on the checkbox of one item, the checkbox of the previous (or sometimes the next) item is also checked. When I click again, both items are unchecked together. I have also seen this happen with more than two items being checked together.
Example 1:
[x] item 1
[x] item 2
Furthermore, when I do this with multi-level checklists, sometimes the level of adjacent list items changes to match the level of the item I checked.
Example 2:
[x] item 1
[x] indented item 2
Clicking on a checkbox (circle at the beginning of the line) should only cause the state of that one checkbox to change and should never affect the state of any other checklist item including its indentation level.
Example 1:
[ ] item 1
[x] item 2
Example 2:
[ ] item 1
[x] indented item 2
Agenda version 7.0, Mac App Store.
