Check lists inside projects
What I did: New Project
What happened: a new project appears
What I expected: make a note where to write my list shopping (for example) and a little square on the beggining of each item to be marked or not.
Thanks to give me the opportunity of telling you what I would like you to include in this app. I’ll appreciate if you listen to me and in the next improve you will add this new thing.
Thank you!
First thing is to keep in mind that Agenda is a note taking app (like Apple’s Notes app), not a task manager app like Reminders or Things. By default (unless you turned this off in the Agenda preferences), if you create a new project it should also create a new empty note. Next you can select the checklist paragraph style if you like to make a checklist for your shopping, see Tags, People, Actions, Links, Lists, and Tables
