Can not copy Agenda Link for saved searches
  1. Search for tag and make a saved search
  2. Select that saved search in sidebar
  3. Edit → Copy As → Agenda Link
  1. I hear macOS “boop” sound (as if action is denied)
  2. Search term gets copied to pasteboard
Agenda link navigating to saved search should be in pasteboard. Not sure if sound is nessesary.
macOS Mojave 10.14 (18A391)
Agenda 2.5 (42)
Indeed these are not yet supported, I’ll have a look to see if we can add support. Thanks for reporting.
Hi,
This article basically answers my question whether there is an AGENDA link for saved search results.
This is obviously the case.
What is still unclear to me is whether the link to a search query now works on Mac OS and iPADos and iOS?
I can’t check that at the moment, because I haven’t yet decided on the AGENDA Pro version. I would like to have this question clarified before making a purchase decision.
Thanks for your response
Guenter
You can make a link to a search query as described here: X-callback-url Support and Reference
