Can it be possible to remove left and right space when you flip an iPad horizontally?
By doing so users can gain full screen access to their worksheets.
Thank you
Thank you
I guess you mean you want the text to go all the way to the edges, right?
Agenda follows Apple’s readable width guidelines. Very wide text is actually difficult to read, with very long lines. Apple promote a readable width, which means putting some space on each side. Note that the readable width depends on text size, so you should see that larger text takes up more space. In essence, it is aiming to get a certain number of characters on each line (approximately).
