What I did: Pressed the “Connect” button for both Calender and Reminders. I did that in both the homepage, and in settings.
What happened: Nothing. The text was initially colored and became grey when I pressed it - staying grey without prompting for permission to calendar/reminders.
What I expected: A prompt to gain access to calender and reminders.
Things that might be helpful to know (Agenda version, OS and model, etc): Latest agenda version. MacOS Sonoma 14.0 (developer beta). Macbook Pro m1 2021.
We don’t currently support the beta of Sonoma. We have not started serious testing on that OS. So it could be due to that.
Try going into the Settings app, and into Privacy, and give Agenda permission to use Calendar and Reminders there.
Hi, @drewmccormack ! I’m also have this trouble. How might one do this in the Privacy settings? There’s no options for me to provide calendar or reminder access to Agenda.
Open the Settings app, and go into “Privacy & Security”. Then select Calendar, and make sure the switch is turned on for Agenda.
Same with Reminders.
