Is it possible to repeat an alert of my calendar event as EVERY DAY or EVERY WEEK or EVERY HOUR?
How can I delete/edit my calendar events which I have created?
- Is it possible to repeat an alert of my calendar event as EVERY DAY or EVERY WEEK or EVERY HOUR?
No this isn’t possible from within Agenda at the moment, you can set this up in the Calendar app.
- How can I delete/edit my calendar events which I have created?
You can do this by clicking/tapping the event in the related panel on the right, then select edit (this is a premium feature), the popover that shows allows you to both edit and/or delete an event.
