Calendar display disappeared on macOs.
What I expected: I tried to figure out the cause but I can’t find it on my smartphone, it works fine.
Could you send us a screenshot of the calendar/locale settings you use in the Settings app under General > Language and Region?
Thanks, that’s very helpful, we’ll do our best to fix it ASAP.
Update: I’ve found the issue and it will be fixed in the next update (13.1). Many thanks for reporting the issue and helping us fix it.
