Created a template with \shared-input action
Passed this markdown in template-input as part of an x-callback-url Create
# Journal Entry for Fri, Dec 04 2020
## Calendar Entries
- Magic Sleeve Limited Edition
- Beth - PT
## Tasks Completed
- Test 2 Due: Dec 4, 2020 at 12:00 AM Completed: Dec 4, 2020 at 7:08 PM
- Test Due: Dec 4, 2020 at 12:00 AM Completed: Dec 4, 2020 at 7:08 PM
Markdown was not parsed correctly
Image of result:
Having that exact same markdown inside the text parameter to x-callback-url create works fine.
Replacing the \shared-input action with that markdown should also work correctly.
Agenda 11.2
iPadOS 14.2
iPad Pro 11 inch 2018
Could you share the exact callback url you used? Could this have been caused by incorrect escaping?
The callback URL is:
agenda://x-callback-url/create-note?project-title=Journal 2020&title=Text&on-the-agenda=true&date=Current Date&text=Text
Title=Text, Text=Text use the Magic Variable from two different Text Shortcut actions.
I am currently not using a URL encoding action, but I am sending the above into a URL Shortcuts action which apparently does encode it…
Body Text is:
# Journal Entry for Sun, Dec 06 2020
### Calendar Entries
- Haircut and coloring
### Tasks Completed
- Update numbers timesheets with timesheet.app data Due: Dec 6, 2020 at 12:00 AM Completed: Dec 6, 2020 at 9:48 AM
- Generate tip report for Ixtapa RR Due: Dec 6, 2020 at 12:00 AM Completed: Dec 6, 2020 at 10:32 AM
- Computer Data Management Due: Dec 5, 2020 at 12:00 AM Completed: Dec 6, 2020 at 11:11 AM
### What did I do?
- xx
### What did I learn?
- xx
### How do I feel today?
- xx
### Food eaten today
- xx
The Shortcut ends with:
Sorry, please ignore that last reply… I was pulling from the wrong version of the shortcut.
Ok, trying again with the correct information.
URL:
agenda://x-callback-url/create-note?project-title=Journal 2020&title=Text&on-the-agenda=true&date=Current Date&template-name=Journal Entry&template-input=Text
Journal Entry template content::
\shared-content
### What did I do?
– xx
– xx
– xx
– xx
Template-Input content:
### Tasks Completed
Final note in Agenda:
### Tasks Completed
What did I do?
– xx
What did I learn?
– xx
– xx
Food eaten today
– xx
I did some experimenting and found a workaround…
If I start the template-input with a newline the final markdown output looks as it should.
This fails to format properly:
– Haircut and coloring
### Tasks Completed
– Update numbers timesheets with timesheet.app data Due: Dec 6, 2020 at 12:00 AM Completed: Dec 6, 2020 at 9:48 AM
– Generate tip report for Ixtapa RR Due: Dec 6, 2020 at 12:00 AM Completed: Dec 6, 2020 at 10:32 AM
– Computer Data Management Due: Dec 5, 2020 at 12:00 AM Completed: Dec 6, 2020 at 11:11 AM
This formats normally:
### Tasks Completed
Thanks, that’s very helpful, we’ll investigate what the difference is.
