When I try to write a tag or a person, the recommended text is overlaying the New button in both cases.
Oh, that is odd. Does it help if you completely quit the app? Ie bring up the list of apps by swiping from the bottom, and then then swipe the screen of Agenda off the top to quit. Then launch it again.
Yes, I already try that, closing the app and reopening
Huh, yep, I have been able to see it myself. We will look into a fix. Thanks for reporting it!
At the moment I’m using the Markdown Shortcuts @ for person an # for the tags
I have fixed this, and the fix should be out soon.
