Imagine you are showing someone something at work, and you accidentally click on a private project. It will bring up the sheet to authenticate, and you can just press cancel. No problem.
But if we automatically trigger Face ID, it could unlock immediately, and you would accidentally reveal your private project.
The situation is a bit different with Touch ID. That requires a deliberate action. We could perhaps investigate if there is a way to force the system to begin that immediately.
