Back up Info
Hi,
I would like to back up my files from an iPad to a thumb drive or to my computer. How do I go about doing that?
Thanks!!!
Katie
Hi Katie,
Usually you would backup an iPad to iCloud. That is Apple’s built in system. You can arrange that in the iCloud section of the Settings app.
You can also backup to a Mac using Finder. Here is a good article explaining it. How to Back Up Your iPhone or iPad to a Mac - MacRumors
Finally, Agenda does support exporting projects (not the whole library though). So if you just have a few very important projects, export them to the Files app, and they can be accessed elsewhere. Use the ā€œAgenda Fileā€ format.
