When I type the @ sign and the first letter or two of a person’s name, it would be great if Agenda could try to auto-complete it for me based on previous Person tags, so I don’t have to type out the person’s name in full.
I use TypeIt4Me for now to approximate this functionality
Agreed. We would indeed like to have autocomplete for tags and people. It’s high on our list. Stay tuned!
I found a problem this morning when I tried to create a tag using the tag command “new" on iOS:
So: If I write: #date(feb 7,2019)
and hit the space key everything is fine and the tag is regularly created; if I use the key “NEW” (see pic attached here) I had a lot of problems, because I can write the date regularly inside the orange strip, but when I hit space or enter part of the date jump off the tag.
Is this in version 5 or 4?
Agenda iOS is on version 4.1
Ok, thanks for letting us know, we’ll investigate.
Hi Alex, I am testing the version 5 right now and the problem is even there. I will tell more about the new version later.
Yeah, that’s what I would suspect indeed
This is a known issue. You can’t currently use the NEW button to create more complex tags, just simple ones.
