Attachments, Images and Drawings
…based on this and experimentation I gather that after a file is attached it cannot be edited anymore, correct? For instance, if I attach a text document it becomes a file within Agenda no longer associated with what I just dragged from disk (that’s fine as Agenda can serve as a storage of its own). However, I will not be able to continue working on this file, editing it, even if Agenda is my chosen storage location for this file. The only way is to link instead of attaching. …is my understanding correct on this?
That’s correct.
My approach is to open the file from Agenda, and when I save, MacOS prompts me to save it as a different file (since the original file from Agenda is locked). Then I attach that newly-saved file to Agenda.
Personally I really like this: I know that any files attached in Agenda are safe, and can’t be inadvertently modified. It does mean a couple extra steps if I do in fact want to modify an Agenda attachment.
That’s indeed the rationale. At the same time we would like to make it easier to edit attachments down the road, in a way it’s clear that you would then replace the attachment.
Is there a way to set the default setting when inserting attachments as “inline” instead of “full width”? Driving me bonkers changing every attachment. Thanks!
Not at this point, no. We will consider this as a future feature. Thanks for the feedback!
:thinking: Storage capacity is limited by my iCloud Storage free?
Yes, Agenda’s files, attachments, and data is stored in your personal iCloud storage and counts against your personal iCloud drive quota. This also means you are the only person who can access your files and they are not stored on our servers.
I signed for premium account to support this excellent team of Agenda!
Thank you!
hello, I’m not getting the same options on IOS that I do on MacOS. I am clicking and holding on the file and the options that come up are:
Display:
Inline
Thumbnail
Thumbnail & Title
Full Width
Actions:
Preview
Share
Copy
The “open” option is not there. What am I doning wrong?
iOS works a bit different to macOS with files. If you want to open a file in a different app, you would have to use the Share option. That would pass the file over to the other app.
Any plans on adding functionality to annotate other types of attachments? I’d love to be able to attach a PDF and open/annotate within the app without having to first Export, make the change, then reattach to my note. iPad OS, by the way.
It’s indeed something we’d like to add at some point.
Yeah, it would be a good feature , if you are adding ……
Can you do a video demonstrating, how will be a full width photo and a pdf attachment will look like , when we export the note to pdf?
I want to know?
I don’t have premium now. While exporting to pdf, the attachments looks like thumnails and we have to add the contents of pdf and image separately to exported pdf to make it complete.
Will it be same in case of premium?
I searched youtube among your videos , didn’t find anyone demonstrating the above said…
Thankyou
And any plan to add an inbuilt audio recording ……
Here is a PDF and the original screenshot.
Test PDF.pdf (20.3 KB)
We definitely have plans to add audio recording. On the roadmap. Can’t give any estimate of dates at this point. One step at a time.
