If I archive my projects how long will they remain in the archived folder for me to refer back to? Is there a way to export more then one note at a time and still create separate notes in one note?
Archived projects will forever stay where they are until you decide to bin them (just like regular projects).
You can shift or command select notes and choose File > Export
This I’m not sure I follow, perhaps you can describe better what you try to achieve?
