Is there a way to archive an entire “instance” of Agenda? The problem I’m trying to solve is that I used the app extensively for work and I recently switched jobs. I wanted to use Agenda for my new job with a clean slate (unused instance), however I wanted to save all of my notes from my old job.
Is there a way to do this?
Using Mac, Version 5.0
The library is stored in ~/Library/Containers/com.momenta.agenda.macos, which should be included in a Time Machine backup. A migration using Time Machine is therefore one option. The other option is simply to use iCloud. If you sync with iCloud, all you’d have to do on a new Mac or iOS device is to install Agenda, make sure your are logged in to iCloud with the same account, and your notes are automatically downloaded. Finally, you can manually copy the above location to the same place on your new Mac. Hope that helps.
