What I did: Trying to automate(I use Drafts) when a note has a tag that it applies a note color. I have tried to use the callback link and also tried to use apple short cuts
What happened:Agenda follows everything except assigning the note color.
What I expected:When the note is added to agenda the note should be assigned a color that I have preset in Agenda (The name)
Things that might be helpful to know (Agenda version, OS and model, etc): Agenda Version 22.1 (381) - Mac App Store. MacOS is on 26.2 and also on an older Mac Ventura 13.7.8, iOS 26.2.1, iPadOS 26.2.1 and WatchOS 26.2.1
Are you using a template? I don’t think you can add a color with the standard create-note option, but you can make a template in Agenda with a background color, and create new notes from that template.
Eg.
agenda://x-callback-url/create-note?title=My%20Note&text=content&template-name=Your%20Template%20Name
There’s also a template-input parameter you can pass alongside it to fill in template variables. X-callback-url Support and Reference
I wasn’t using a template but you triggered me to try that and see if that works! Thanks Drew
Drew you are the MAN!!! That did EXACTLY what I needed! Thank you so much! I love Agenda and use it DAILY.
Please keep up the GREAT work that you and Alex do!
Chauncey
Fort Myers FL
