jim
February 5, 2018, 9:10pm
1
Not really 100% sure. I was scrolling through a collection of notes, and got the crash.
I attempted to restart. The Agenda Icon in the Dock bounced but I never got a window. The Dock and activity monitor say “Not responding”
For Agenda to launch, optionally with the bug reporter window.
THis is concerning that the work I’ve put into Agenda is not accessible.
1.3 beta, mac 10.12.6
Hmm, that’s odd and indeed nasty. Almost sounds like a sandbox issue. Does it help if you reboot your Mac? If not, does it help if you quit Agenda and delete its preferences by entering in the terminal:
defaults delete com.momenta.agenda.macos
Btw, any chance you could dig up the crash report from the library and send it to us?
jim
February 5, 2018, 10:19pm
5
If you tell me where to look …
If you use terminal again and type:
open ~/Library/Containers/com.momenta.agenda.macos/Data/Library/Application\ Support/CrashReporter
are there any Agenda crashes?
jim
February 5, 2018, 10:28pm
7
The reboot worked and the bug reporter window came up
You should have the crash report now. There is a plist in that directory if you want it.
Pfew, very happy to hear that. I did some googling and indeed it does sounds like the crash caused the XPC process not to give back access to the sandbox. The restart was probably necessary to reset things back to how it should. Thanks also for the crash report, we’ll investigate.
jim
February 5, 2018, 10:36pm
9
the plist is:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>Date</key>
<date>2018-02-05T21:02:25Z</date>
<key>ForceQuitDate</key>
<date>2018-02-05T21:15:53Z</date>
<key>Path</key>
<string>/Users/jgraham/Library/Logs/DiagnosticReports/Agenda_2018-02-05-160236_jgraham.crash</string>
</dict>
</plist>
Not really interesting
Thanks for the help!
Cheers @jim , perhaps the uploaded Diagnostic report tells us more, will check.
