Agenda window too small when sharing from Safari
Clicked the Share button in Safari and choose AgendaNotes.
I think that since iPadOS 18, the window in Safari has changed when sharing to Agenda and is too small.
However, this only seems to be a problem in Safari. In Aloha, for example, the window is large enough.
Is this a bug in Agenda or iPadOS (Safari)?
How can I enlarge the window?
iPadOS 18.1, Agenda 19.2.1
+1 same here, small window when sharing on iPad.
Yes, would be great if this could be fixed.
Thanks for reporting. This seems to have arisen from some change in the OS. We will investigate and fix in Agenda 20.
Thank you.
FYI if it could be related. I rarely use my iPad for data input but on my Mac I’ve had issues on 3 apps since 15.2 with secondary windows. Hookmark’s context window is dead in any app when in full screen mode. Finder, pages, and numbers have an infinitesimal
cursor focal point, almost un-grabable, sizing borders such as columns.
Mac 15.2
Unlikely to the be related, I think. iOS is a completely different beast, and there is not much shared code for the sharing extensions. Probably separate issue.
Would it be possible to join the beta group Drew?
If you want to join the beta, post a comment in this thread: Can I join the Agenda Beta program?
I have fixed the share sheet sizing problem on iPadOS. It will be in the next beta.
Thanks for reporting this!
I would like to give some feedback on this.
The problem has been fixed in Agenda 20.0.
Thank you very much!
Glad to hear! Thanks for letting us know.
