shryn
              1
              What I did: I had a widget on my Homescreen one day.
What happened: The next day it was gone.
What I expected: I tried to replace the widget, but Agenda isn’t listed in the Widget List.
I am running iOS 18 beta on my iPhone 12 Pro Max. I restarted the phone, but the Agenda widgets are still missing from the list.
              That is very odd. It should work even on the beta.
Is Agenda installed from the App Store? Or were you using our TestFlight beta?
              I can confirm this. Widgets gone and no widget available to install.
On Agenda 19.1 (311). I am also on iOS 18.1, Agenda widgets was working on iOS 18.1, but now they are gone.
                shryn
              4
              Agenda installed from the App Store.
              Were you using the Agenda beta version from Test Flight?
              Yes, I am using latest version from flight test. I will install the App Store version and see if Widgets return.
              Widget returned after reinstalling either the App Store version or flight version solved the issue for me.
              It’s very odd. Unfortunately there isn’t much we can do about it. It is clearly a problem in the operating system, no doubt triggered by the upgrade.
Sorry for the trouble.
                shryn
              9
              Good idea. I have reinstalled Agenda - problem fixed. (For now?)
              Hello,
I have the same problem.
Since updating to app version 19.2, the Agenda widget no longer exists on the iPhone and iPad.
Even a new installation on both devices did not help.
I hope this can be fixed with an update… There is currently no update for iOS / iPadOS.
It is clearly due to the 19.2. version.
I don’t know if it’s important, but I use Agenda from the German App Store.
vg
Andreas
              Very sorry. There was indeed a problem. Please install the new 19.2.1 version from the App Store. It fixes this.
