Shortcut works like a champ for me! Thanks!
I have never really bothered with Shortcuts, always seemed like too much effort but this is genius! Thanks so much for sharing
Thanks @gbuell for this great shortcut! I modified it this way: The first line of the Agenda-Note (the Title) will be the Title of a new Things-Project and all tasks are included in this project. There are two Versions: one for āThings 3ā and one for āThings 3 for iPadā
Link to Things-3-for-iPad-Version
I hope it works fine! The project will be created with x-callback and it seems that the Things-URL-Action depends on the App-Version of Things (iPad or normal version).
Im not very shortcut savvy, but is there a way to instead of making a project with to-do items as this shortcut does on ipad to make a shortcut that makes a to-do with checklist items?
This would be useful for adding to an already existing project that you get an update for or more action items for.
Would this work with reminders app as well?
thank you so muchļ¼iām just looking for a short cut to Things 3
Thanks for sharing this shortcut!
I was able to add it to my shorcuts app, however when I run it, nothing happens (other than Things is opened at the end).
What step am I missing?
Are you on iOS14 by any chance?
Yeah - public beta.
Also, I was playing around with āthings helperā on Mac. I canāt seem to get the agenda URL to add directly onto the task. Similar to how it works with the mail app or safari.
Is there a way to quickly get the URL link for a note? I currently right click on a note under ārecently usedā and click ācopy as agenda linkā
Thanks
I believe that at the moment URLs are broken in the shortcut app, @heyscottyj was mentioning this I believe.
Yes, but URLs seem to be performing better as of dev beta 3, so assuming it becomes the next public beta, these would be worth retesting then.
Good luck!
ScottyJ
My shortcut is broken. It used to pull all checkbox lines in an Agenda note, but now itās only pulling the first item. Is anyone else having trouble?
Yep, itās doing the same thing for me. it creates the project via the call in the first portion of the shortcut, but it doesnāt inject the subsequent tasks underneath of it.
@jowarn - have you confirmed that itās working on the iPad version? Iām able to get the title project to be completed, however the individual tasks I canāt seem to get created.
Any thoughts?? Thanks for your help!!
Oh, Iām sorry, I donāt work with Things anymore.⦠when I shared the shortcut, it worked with the iPad version, but since iOS 14 I have some troubles with other shortcuts, maybe there are new commands that work betterā¦? Iāll try to look at it.
@jowarn is there a way to do this with GoodTask? Iām using it a lot and would love to Set some shortcuts but both have a weird way to set up shortcuts between them.
I think it must be possible only if GoodTasks is supported by Apple Shortcuts, then you can replace the Things-Shortcut by an GoodTask-Shortcut but I donāt know it.
Hi, does this Shortcut still work? If I share a note with checkboxes it runs and opens Things 3 on iOS 16.1 and iPadOS 16.1 but no entries are created in the Things Inbox.
I also tried those now (but still prefer to get them into the Things 3 Inbox) but the iOS version creates a new project in Things but doesnāt transfer the checkbox items - no idea what is wrong?
