Another suggestion that I would love to have on Agenda would be to build a good integration pathway for notes made on Agenda and “Anki” flashcard app…(or notability, but mostly Anki is important to transfer notes to). It would be the best thing to ever happen!!!
Anki also uses a lot of codes and programming-type functions, which may make it possible to easily turn your notes into flashcards AS you’re taking notes!!
Assuming Anki provides a service for creating a flashcard, can’t you just select the text and choose Agenda > Services?
I think you would need to be more clear about the type of integration you would want. What would the workflow look like?
The title of the note becomes the front of the flashcard and the note’s content goes on the reverse side
