Agenda doesn't recognise indentation using spaces
Hi,
When pasting lists that use spaces for indentation, Agenda doesn’t recognise the indentation and pastes everything at the same level.
e.g.
  • Bullet 1
    • Bullet 1a
    • Bullet 1b
    • etc…
Becomes:
  • Bullet 1
  • Bullet 1a
  • Bullet 1b
  • etc…
In other markdown-supporting software like Notion and Obsidian, the indentation is recognised.
Thanks,
Alex
I believe this depends on the format that these apps put on the pasteboard as I’m pretty sure there cases where we do turn spacing into indentation upon pasting text. We’ll check.
Thanks
