Agenda crashes in Catalina Public Beta
What I did: launched Agenda after installing public beta of Catalina
What happened: crashes all the time under Cataline
What I expected: a bit ore stability
Things that might be helpful to know (Agenda version, OS and model, etc): Process: Agenda [5169]
Path: /Applications/Agenda.app/Contents/MacOS/Agenda
Identifier: com.momenta.agenda.macos
Version: 5.5 (78)
App Item ID: 1287445660
App External ID: 831194593
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Agenda [5169]
User ID: 501
Date/Time: 2019-07-02 11:43:49.036 +0200
OS Version: Mac OS X 10.15 (19A487m)
Report Version: 12
Bridge OS Version: 4.0 (17P50482j)
Anonymous UUID: 1E99192D-50FC-3391-ED7F-34D648BEF4E8
Sleep/Wake UUID: 5CB13412-1D28-4981-B570-9BD970DB0366
It’s beta software, we don’t support Agenda on Catalina yet. Having said that, we’ll obviously dive into things to ensure it will work properly when 10.15 comes out and as such it’s good you reported the issue!
Did you submit the crash reports from within Agenda? And could you please send me the crash reports still present on your Mac to alex@agenda.com? You will find these in the following place on your computer, in your home folder:
/Users/your_name/Library/Logs/CrashReporter
or
/Users/your_name/Library/Logs/DiagnosticReports
The crash reports will include the name of the application in the file name , look for the application name ‘Agenda.app’.
To access your Library folder, you need to use the Go menu in the Finder and press the option key. This will add a ‘Library’ item to the list, and will give you access to the hidden folder.
In addition, let us know if you see any relevant log messages in the Console app (which you will find in /Applications/Utilities/Console).
Alex
