when copy some text like
11 ‘’’ “””```
and paste to angenda
it will be changed
11 ‘’’ “””```
it will be changed
Agenda uses some markdown shortcuts for styling code. The easiest way to avoid having that is to use the Preformatted paragraph style, or the fixed width style. If you set that first, then paste, it should stay the same. This is good for code.
