I’m using agenda with ipad and pencil to take a notes
i can’t write a new note with the pencil
i need to know how use agend to take a hand write note with pencil
There are two ways you can use it. You can use Apple’s Scribble technology to write words that get transformed immediately into text. To do that, put the cursor in a note, and just write near the cursor. It would change into words.
The other way you can do it is as images of the text. To do that, put the cursor in the text again, but this time tap the + button just above the keyboard at the bottom of the screen. You should see a squiggle line. Tap that button to start writing. Whatever you write will save into the note as an image which you can open up for more editing.
