Agenda 21 and upcoming features
Hi there,
Just curious if there’s anything to share about Agenda 21 and what the main focus of that version will be?
I’m hopeful we will see Contacts app integration soon! :slight_smile:
We would certainly like to add the contacts integration. It’s high on our list, but we’ve been diverted a little by what Apple wants to push from WWDC.
We have to be mindful of their direction, so it looks like Agenda 21 will be about things from WWDC. Some new look for macOS/iOS 26, and a new feature around Apple Intelligence.
Contacts will come though. It is a priority issue for us.
hope we can have grammar check on iPadOS and iOS in the near feature~~~
I stumbled on this apple developer link!
Makes sense that some work needs to be done with Liquid Glass coming in hot. I’m glad you prioritize that to stay modern and relevant; the new design has grown on me during my usage of the betas.
Doesn’t iPad/iPhone have a standard grammar check? I just assumed that was built in to the system. Are you sure it isn’t?
You do have writing tools now, so you can use that to proof read, which I assume helps with grammar.
Yeah, our UI is pretty custom, so it is actually a pain in the neck. We’ll see what we can do.
hi @drewmccormack , sorry I may missed, does Agenda now support spellcheck in iPadOS Spellcheck is not working in iPadOS - #19 by drewmccormack
I think it does support it, but the correction squiggles unfortunately get erased after a bit.
I think it might depend on the spelling setup you are using too. I think you can have squiggles, or autocorrections.
I will look into this to see if there is a workaround.
Yes, I can have autocorrections for now but it would be better to have the same experience of the squiggles as Mac which is always on. Hope it can be implemented. Thanks for the response.
