Adding A Newline
Tap the + icon
Blank note added to the bottom of the notes stream
Added to The Top
Had to scroll through notes to the bottom. Then move to before first note
This should be an easy fix but there’s no easy way to change settings in Agenda
Agenda 2O
@1581 have you checked how the project is set to sort? Click on the project in the TOC to do so.
Yes, most likely the sorting of the project.
Tap the project title, and then button top-left, to change it.
