My question is more or less a feature request.
For me (and i think for more people) it would be usefull if there are weeknumbers in the agendaview.
Just as reference to easy see the the 23th of august is in week 34.
You can turn on week numbers in the Agenda preferences since the last update.
Wauw.
That is support.
Problem solved ahead of the question.
I think i missed the announcement.
It would be super amazing if we could adjust the week number to fit our organization’s fiscal calendar
I’m afraid this is the level of customisation that we can’t offer, unless it’s something you can change in the system preferences (in which case it will be automatically supported in Agenda too).
