Works like a charm now in V. 13.1 (194) . Thanks a lot.
hi! is there any way to have that in calendar window, that I have when assigning the notes?
Following many European companies procedures, I used to work with week tasks and assign the tasks per week - for now I have to use Mini Calendar to map data to the week; it would be so cool to have this inside of the app
If you have the show week number option in the preferences and select a day in the calendar popover, the description at the bottom of the window will tell you the week number:
Thank you. Could work as work-around, but itβs a bit clumsy to click through the dates, if I need to find right weeks.
