In the settings menu - the Purchased info at the bottom uses a green checkbox no matter what color theme you choose
This is great.
Where its not great is in a Project.
When I complete a task, it needs to change color, just the check box would be fine - here’s the issue: right now the visual distinction between tasks that are complete as opposed to those in progress is slim to none. They look too much alike.
