Like the note, it would be beneficial to be able to apply colors or other formatting to the title, in order to highlight one or more notes in relation to the others, especially if there are collapse.
I don’t know if my explanation are understandable ?
I see what you mean, the title is plain text at the moment so for technical reasons it’s not possible at the moment, we’ll take your suggestion on board. You could however use the note background color to highlight notes with a specific color, this should be visible also when collapsed.
