Text highlighting - Toolbar for most used formatting options?
It would be great to have an easily accessible toolbar or pop-up tool palette with the most frequently used formatting options.
I often work with long texts and use highlighting quite frequently. Unfortunately, the highlighting option is buried several levels deep in the menus. It would be much more convenient to have a quick-access option that remains visible while formatting text.
Is something like this already available? If not, it would be a great feature to consider for future updates.
Thanks for the feedback!
If you are on a Mac, there are a couple of things that may help.
View > Show Formatting Palette (Option-Cmd-I) opens a small formatting panel that stays visible while you edit. You can drag it to make a window.
There is also a shortcut for highlighting: Cmd-! (Cmd-Shift-1 on most keyboards). It highlights the selected text with the last colour you used, so pick a colour once from Format > Highlight, and after that it is just the shortcut.
We’ll take the toolbar idea along.
Thank you for your reply and for the tips on shortcuts. I wasn’t aware of these :wink:
A pop-up toolbar with the color palette would still be a great addition for quick and easy highlighting. Thanks for considering it for a future update.
Glad the shortcuts help!
