Text editing problem in Korean
textediting
#1
I wrote a text in Korean and copy & pasted a sentence.
Text disappeared when I hit enter key after pasting(command + v) a sentence.
I found that word randomly disappears when I hit enter or delete key.
iPad 12.9 1st gen - iOS 12.1.4
I have a video but I can’t upload because I am a new user.
#3
Can you send the video to drew@agenda.com?
Check your mailbox!
I hope it gets fixed soon :smiley:
#5
Got the email. Thanks!
It does look, indeed. I tried to reproduce similar things using a Japanese keyboard, but I couldn’t. I will try Korean too, but is there some action I should be doing to trigger the issue? Are you just typing normally? Or do the problems start after you do a particular thing?
Best check you are on our latest version too (5.5).
I sent an email with one more video. I used iOS software keyboard this time, so you can check what I typed visually. I checked that the version number was 5.5.
I guess there is a problem with buffering latest word of a sentence, because I just typed normally and always latest word disappears.
#7
I did some testing with the Korean keyboard on my iPad, and I still can’t make this happen. I can’t make the last word of any sentences disappear.
Is there something special I need to do, like entering a question mark or something?
Are you hitting any special key combos?
I guess you don’t have any special text extensions installed or anything, right?
Are you just using a standard keyboard from Apple?
Are you syncing with another device, and do you have the other device running when you do this test?
I notice you are editing the Welcome projects. Does it happen with a new standard project? The welcome projects are handled a bit specially.
#8
I am using iOS default keyboard from apple(no extension) or iPad(12.9 1st gen) Smart Keyboard. System locale is set as Korean (한국어).
I tested again with sync offed, new standard project (not Sample projects like Welcome) and still happens.
I typed no special key combo or character. I guess you can make this happen with typing very simple word like “가가” with spacing and line breaking. I guess test case needs long enough text.
For example:
가가가 가가 가가 가가가 가가 가가
가가가 가가 가가가가 가가 가가 가가
가가가 가가 가가가가 가가 가가
가가가 가가 가가가 가가가가
가가가가가 가가 가가가가가
… (and more)
#9
Does it happen if you use the onscreen keyboard? Does it happen on your iPhone, or just the iPad?
#10
It happens in both all case. iPhone and iPad (onscreen keyboard / smartkeyboard).
I did some testing with OSX version, I can’t make the word disappear this time. I don’t know what’s the difference.
