Explaining the above better, when you write a #text, after pressing space, it automatically create a tag for agenda. The problem is that I use text replacement for my tags (I use emojis). So, for example, a #project becomes #, however, agenda kicks in a #project before it can be converted to the suitcase. I thinks it is a simple fix, but would be helpful for me.
Unfortunately the text replacement system doesn’t inform us when it does its thing, which means we can’t discriminate it from other text editing actions. As a result I’m afraid there’s not much we can do here
Hey, that’s fine, I’m managing to add all my tags, so they are just loaded and I can easily select them upon pressing #, thanks anyway!
Perhaps I’m misunderstanding your goal. You can click on an existing tag “#project” > manage tags > click the 3 dot menu > edit tag > double click the emoji you want and all instances will be replaced .
