I’m a new user, in general really enjoy the product, but could not get sync working. The sync kind of works, but only partially. Some projects are synced, some are not (tried both with Dropbox and iCloud )
I set up Agenda on MacOS (I’m a premium user), turned OFF sync and created some categories, added some projects, notes, etc.
A bit later I gave a try to the iOS app. Turned the sync to Dropbox on MacOS. Installed the iOS app, discarded the sample projects after the tutorial, and turned the sync to Dropbox.
Some of my project were synced to the phone, some were not. The categories were also missing. I tried to remove the iOS app, and install it again. When I created something on my phone, I could see that in MacOS, but everything looked really random.
I’ve decided to swith to iCloud. Switched the sync to iCloud on MacOS (deleted data from Dropbox). Did the same on iOS. The result: some other projects were visible, but still not everyting.
Also tried to check previous issues here, and for example logged out from my iCloud account both on iOS and MacOS, deleted the app multiple times, without much luck.
Any help would be appriciated
Sync works
MacOS Version 13.1.1 (195) - Paddle (Big Sur)
iOS Version 13.1.1 (iPhone 12 Pro Max 14.6)
I have only 5 projects with 3 categories, and just 4-5 notes per projects
