Hi there,
New user but I really like the concept. Unfortunately some of the information seems to disappear in notes. Some times it comes back but then it will disappear again. I’ve taken a picture to show what I’m talking about but this won’t let me upload it (does this instead
I’m using the app on the Mac OS if that helps.
That’s odd, a few questions:
Do you have any notes collapsed in your library at all?
Does it happen right after you switch from a different project or at startup?
Does it always happen with this note?
Hi Mekentosj,
I did not have notes collapsed in my library, and it happens when I switched projects or even if I was just scrolling in my note. It happened with multiple notes, not just this one. I stopped using Agenda for a while and when I came back the problem went away! I’ll let you know if it comes back.
Very odd, let us know if it indeed comes back, thanks for the follow up.
