Simple Search
That is exactly how it used to work. It would show the search results in a list similar to Inbox. The issue was it took you out of your context, replacing what you were doing. You could hit the back arrow to go back, but it was “heavy”.
There may be a few things we can improve here. Seems one issue people have is just not being able to see all the matches in the note at once. I think that is very fixable. Will do that.
And even the other could be an option. Perhaps a button that splits off a separate window with the search results, so it doesn’t disrupt your editing, but allows full scale browsing. Will look into it.
Thanks! This clarified the issues well.
It does little working with one at a time when possibly working with multiple cat/projects. I imagine most searches are to copy\link\edit things you find. It’s like finding scattered 100 dollar bills but can bend only once. Highlight retention would be a huge improvement.
Perfect. Second windows need more use.
I’d like to add one more point.
Agenda on the iPhone will never offer the same user experience as it does on the Mac.
The iPad has come a bit closer to the Mac, but only when used with an external keyboard.
Actions that are effortless on the Mac can become a real chore on the iPhone.
Agenda has handled this well so far, and it should remain that way in the future.
So please, keep it up!
? never mind
? no, go ahead
I’m sorry, I didn’t see this response/question.
I save notes in Agenda in different Categories - my law office, my title agency, and my personal life. I live and die by my calendar, so having the calendar event have the Agenda link is why I love using this app.
In any event, due to my days being busy with a few businesses, my personal life, and the matters that I handle for my clients being over 100 at any given time, I like to be as efficient as possible. Ideally, I don’t like to have to use the mouse if I can get an app’s shortcuts memorized.
In Agenda, I love the CMD-F shortcut, as that’s what I feel the shortcut should be to quickly bring up a master search. I usually search using tags and people, so if I search for @LD (one of my employees) and I hit RETURN, I get a long list of notes that apparently have her tagged. In order to navigate through those, I have to click on each one, if the title of the note I’m looking for doesn’t jump out at me.
To navigate, I use my mouse, or I can navigate down with my arrow keys. When I then highlight one that I want to check on, I click RETURN or click on the note title. That then takes me to that project and that note, but other notes show up in the visible list, so it’s not clear where the @LD is located in the paragraphs of notes that are shown. I have to then click on the note from the CMD-F list a second time in order to have the tag pop / highlight to show me where to look.
Then, if that wasn’t the note I was looking for, I have to type CMD-F again to bring the list back up again, then I have to click on the next note to see if that’s what I’m looking for.
I will try to type other words in the search box as well to narrow down the results, but most of those words, tags, and/or people will appear multiple times and in multiple notes over the course of the projects, so I’m never quite sure which note to click on when looking at the titles in the search results. I will also find that when searching with search terms and tags, there are no results, so my memory for what the search terms would be differs from what I apprarently typed at the time. While that is my memory problem, it’d still be good to get a list of notes that might be what I’m looking for or at least have some of the search terms.
Usually, if I narrow the search down to 3 or 4 notes, I will find the one I’m looking for in a minute or so, but I likely could have found it just as quickly by navigating to different projects and scrolling through all the notes to try and find the one I need.
I’m not a product designer, so my feedback probably doesn’t help much. Also, I might be using the app incorrectly, and maybe there’s an easier way to find the list of notes in a search window instead of the CMD-F results list?
But searching and only being given a list of note titles to click through one by one makes it difficult and time consuming for me. I tend to revert back to using Things3 and just pasting Agenda links in tasks and projects in that app. The functionality of Things3 with keyboard shortcuts is what I wish Agenda had because in that app, I can click CMD-F, get a quick-results list to pop up that might show me what I need, but if not, I can hit RETURN and get every project or task that has the searched text/tag. If Agenda had that quickness and ease of use, I’d likely ditch Things3 and
agenda list.pdf (104.5 KB)
never use another app.
Thank you for listening/reading, and please let me know if I am just doing something wrong in my use of Agenda, as that is quite likely the true problem! Love the app, and thank you for your continued development of it!
Thanks for writing that out, it really helps.
A few things that should make it quicker for you now:
  1. The problem where you had to click a result a second time before the match was highlighted was a bug. It is the same one Roms found above, and it is fixed in a recent update. Make sure you are on the latest version. If it still happens, let me know, and whether it is only for notes in other projects.
  2. Once you are in a note, Cmd-G jumps to the next match. When you reach the last match in that note, it moves on to the next note in the results. Shift-Cmd-G goes back. So you can step through all the @LD notes from the keyboard.
  3. If you want to read through all the matching notes, use the button at the bottom of the search list that opens the search notes in a separate window. You get all of them in one scrolling list, and your main window stays where it was.
  4. When you type several terms, a note has to match all of them. If you want notes that have either term, click the second term in the search field and set its Filter Mode to Optional. Excluded leaves out notes with that term. You can also type OR or NOT (in capitals) before a term, eg “@LD OR budget”, which does the same thing.
We are also looking at highlighting all the matches in a note at once, as discussed above.
I’m not sure if this belongs here: I have a different problem with the search function…
I have a note titled “Koga Miyata.” When I search for “Koga” on my iPhone, it doesn’t show up.
But it does show up on the iPad…
And on the MacBook, too…
I don’t understand why the note can’t be found on the iPhone, and it really undermines my confidence in the search feature’s reliability.
I had already suspected that the search index on the iPhone would need to be rebuilt. However, I haven’t found any similar cases here on the forum, and I can’t imagine that I’m the first person to encounter this problem.
Best,
Michael
@BruceN I forgot, we already have this. Run a search, then click the button at the bottom left of the search popover (“Open search notes in separate window”). It opens all the matching notes in a separate window, so you can browse them without leaving where you were.
@michael_e Each device keeps its own search index, made with Apple’s Spotlight. Sync moves the notes, but each device indexes them itself. So the iPhone can miss a note that the iPad and Mac have found.
The easiest fix is to open the note on the iPhone and make a small edit, eg type a character and delete it again. That makes the iPhone index the note again. Then search again.
If you find a lot of notes missing on the iPhone, let me know.
However, there’s a problem with this.
For example, I’m searching for “ABC” or “DE-FG.”
To search for “DE-FG,” I have to put it in parentheses. So far, so good—if I remember to do that before typing.
It becomes problematic when I deliberately and carefully enter the following in the search field:
ABC OR (DE-FG)
This is the result
Thanks @drewmccormack, editing the note helps to find it again.
There are several notes that can’t be found. My problem is: I don’t want to test each note. I’d appreciate if there is a solution to start a general reindex process.
@Roms That looks like a bug. When OR and the parentheses go in together, the search field drops the parentheses and splits DE-FG into two words. Until we fix it, try entering the parts one at a time: type ABC and a space, then OR and a space, then (DE-FG) and a space. Each part then becomes its own term before the next one starts. Another way is to leave out OR and set the DE-FG term to Optional instead.
@michael_e There is no button to rebuild the whole index at the moment. The iPhone only rebuilds it after certain updates, or when iOS asks for it. The one way to force it is to delete Agenda from the iPhone and install it again. The index goes with the app, and when the notes sync down again, the iPhone indexes every one of them. That can take a while on a big library, so keep the app open until it is done. Before you do it, check that all your notes are on your iPad and Mac.
A rebuild option is a good idea. We’ll take it along.
Thank you for this, I’ll try these suggestions.
#3 sounds like what I’d prefer to see / use. Is there a keyboard shortcut or workaround that will automatically open up this scrolling list in a new window instead of having to click the button at the bottom?
Thanks, @drewmccormack , for responding so quickly.
There’s one more thing that fits well here.
Over a year ago, we discussed searching within folded notes in this post. The solution was a Shift-click feature, but unfortunately, it’s only available on the Mac.
On the iPhone and iPad (without an external keyboard), I still feel very left out when it comes to this feature.
My experience on the iPhone:
  • My notes have very similar titles
  • I can’t tell from the search results whether the notes are folded.
  • I tap a note title in the search results and am taken to the folded note. I can’t see any more there than I could before.
  • I double-tap the note title to expand the note and now see the content, but not what I’m looking for.
  • I go back to the search results and tap the now-highlighted title again
  • I’m taken back to the same note, and only now do I see the highlighted result.
I have to do this over and over again for every result, one after another. It’s annoying, and to me, it doesn’t feel like a well-thought-out feature!
It would be easier if the folded note always opened automatically. Then I could check the contents right away and fold the note back up immediately afterward.
@MLB There is no shortcut for that button at the moment, and no setting to always open the list in a window. Two things come close:
  • Option-click a result (or hold Option and press Return) to open that one note in its own window.
  • Save the search as an overview, with the button next to the separate window button. Then select the overview in the sidebar and press Cmd-O (File > Open In Separate Window). That works well for a search you run often, like @LD.
@Roms You are right. On the iPhone and iPad, tapping a search result does not expand a folded note. That is what Shift-click does on the Mac, and there is no equivalent on iOS yet. For now, expand the note first (double tap the title), then tap the result. Opening folded notes automatically from search makes a lot of sense.
The tricky part is when you collapse the note again. Eg. imagine you start working in that note. You don’t want it to collapse on you. So it has to stay in a sort of temporary expanded state. I can imagine a few situations where it could get confusing. We’ll see what we can do.
Am I understanding this correctly? You mean the note should collapse on its own again?
It doesn’t have to; I can collapse it manually after reviewing or editing it.
Or just don’t collapse them anymore. The reason I collapse completed notes in a project is to stay focused on the note I’m currently working on. That way, older notes that I’ve expanded via the search no longer distract me.
Thanks Roms, that makes it clearer. If you are happy to collapse the note again yourself, it gets simpler: tapping a search result could just expand the note and leave it open. We’ll take that into account.
