The sidebar doesnot redraw unless I quit the app and relaunch. Also it would be nice to reorder my sidebar categories and projects in the order I prefer.
Do you mean after adding a project or after adding a category, or both?
This is something we would like to allow for in a future update.
the redraw seems to happen only when i delete a project or category.
this is a great app, so useful, keep up the great work!
Apologies for not yet getting it. First, when you say doesn’t redraw I assume you mean doesn’t update to the new situation? Or is there a drawing glitch of some sort?
Then for each of these can you indicate it the sidebar updates for you?
add a new category
rename a new category
add a new project
rename a new project
delete a project
delete a category
If it helps, please add one or more screenshots.
