aymaco
January 14, 2020, 2:55am
1
Hi, I’m using Drafts to save to Agenda.
I changed the project name to emoji icon, so the process can’t be finished.
I’m wondering if I set anything wrong?
Or just Agenda doesn’t support emoji shortcut?
That’s my callback URL:
agenda://x-callback-url/create-note?project-title=📥&title=[[title]]&text=[[body]]&on-the-agenda=true
I think maybe the problem there is that URLs don’t support emojis. You probably have to use percent escapes.
Go to https://www.urlencoder.org , and fill in the emoji text (not the whole URL). Encode, and it will give you what you need, namely, %F0%9F%93%A5.
Then fill in that for the emoji.
agenda://x-callback-url/create-note?project-title=%F0%9F%93%A5&title=[[title]]&text=[[body]]&on-the-agenda=true
I think that should work.
aymaco
January 15, 2020, 7:40am
3
Wow, you are awesome! It indeed worked!
That’s a cool online tool!
You can also (if desired) do this inside Shortcuts by sending text to a URL Encode action. I’ll often do this with everything going in to a URL scheme, just in case.
ScottyJ
