Using Shift-Opt-(drag-select-text) works to select text in the expected way until you end the drag-select, then it reverts only to the first line in the selection.
Context: I keep a daily log and copy/paste into Slack for daily status. The bullet points don’t play well with Slack. I experimented to see if I could mult-line-select similar to Xcode, leaving out the bullet points. I was delighted when it seemed to be working on my bullet list until I let go of the drag.
Secondary to this, I’d love a way to copy the note contents as Markdown. Incompatible elements could be inserted as description placeholder text or dropped entirely. It would greatly improve my workflow.
