I love the function, to have fast action on notes (on macOs):
- option-mouseClick: markes the note as done and removes it from the Agenda
- command-mouseClick: set oder removes a note from the Agenda
My question: Could you please make the second feature available for collabsed notes too?
While the first «short-cut» is possible for both, expanded and collapsed notes, the second only works on expanded notes.
When I set up my Agenda, I normally get an overview with all notes collapsed and then set a few of it on the Agenda. I know, I can do this by using the keyboard short-cut cmd-shift-U; but since you have the feature for expanded notes, may be it is not that hard to make it available for collapsed ones.
